I did not include it as I am not certain if it counts but any lock mechanism that when released lets the blade swing from from open to close and vice versa effectively allowing it to be an opening method would be up there near the top. Example would be an Axis lock with a blade that can swing free.
I should have read your reply before I posted mine, as I said the same thing regarding the grip and the opening hole. I agree completely. If you’re just fidgeting by opening and closing a knife, probably that doesn’t matter, but if you’re actually going to use a knife to cut, it’s nice that the opening mechanism puts your hand in position to grip it for use.Spydie holes or other similar holes like on the grip sheepfoot, for objective reasons.
You can get an immediate grip after opening your knife with a hole, which isn't the case with other mechanism. That alone makes it the best opening. With other mechanism, you have to fiddle a little after opening it in order to have a grip, which can slow you down in emergency situation or make you drop the knife if you're in a hurry. You flick a Spydie hole and you have the perfect position to grip the knife immediately.
That's a more minor point, but it also help to shelve some weight out of the knives with practical benefit. A thumbstud adds weight and geometry, in comparison. The only thing I would like to confirm is if the hole can be a point of fragility on a blade. That would be my only reservation about the Spydie hole.
A flipper naturally adds a guard to a knife, which is safer than having your fingers exposed to the sharp edge. On framelock, it can also help you to close the knife in a safer manner, since the guard will always prevent a bad "drop bite" when closing the knife quickly. Flippers are far from being a fad, they have practical reasons to exist.
I don't have any personal preference myself, I don't even like Spyderco knives that much, but the Spydie hole seems to be the most practical of them all and the best design overall.
All in all, we rarely use our knives for emergency situation though.
Emerson Wave.
Then comes flipper, hole, and thumbstuds. In that order.
I also enjoy when a knife has multiple deployment methods.
That is one heck of a nice knife and the dimensions would be utterly perfect for me!I like regular flippers fine, but I prefer that they have a blade opening hole as well, like the Koenig Arius. If I’m opening a knife actually to use it, using the opening hole puts my hand in position to use the knife immediately, unlike using the flipper tab. Middle finger flicking an opening hole is my preferred method if I’m putting the knife to use and not just fidgeting.
I like front flippers especially when the mechanism improves the handle ergonomics. I have problems finding knives that fit my XL hand well, but one of my favorite knives is the Burger EXK Plus, which has a 2.75-inch blade and a handle length of just 3.75 inches. But since the front flipper design puts no flipper tab in the way of my hand, the entire handle length is available for the grip. Nice!
Of course other opening mechanisms have this advantage, too, e.g., thumb studs or opening hole. But the front flipper doesn’t alter the blade surface, and tactilely it’s enjoyable to use.
I've seen alot of talk online that the flipper tab is a fad that's beginning to fade. Seeing alot more holes, rather that's a spydie hole or a rectangle or whatever alot in the custom world. So which do you prefer?
