- Jul 25, 2007
I'm running argon into my kiln at a rate of 4 LPM (8.48 CFH). The kiln chamber is 16L; I would think 4 LPMs is more than enough to purge out the oxygen.
If I go below 4 LPM, I start to see surface scale/pitting. If I go above 5 LPM, the heating elements can't keep up with the incoming cold argon.
At 4 LPM, my knives come out with little/no scaling/pitting, but the surface hardness is 5 points below the core hardness. The decarb layer is more than a few thousandths thick.
Those who are running argon into a kiln - what flow rate are you using? Any recommendations as to how I might seal the oven door when firing? Thanks
