Heres (2 ) Olight flashlights that are brand new. NOTE: On the S10 Model. I did install a battery to test it and the lanyard that came with it but otherwise, its never been carried and only turned on a few times.
The Specs. are below
Olight S10 LED Flashlight - 400 Lumens - Cree XM-L2 LED - Uses 1 x CR123, Asking $42 shipped
The S10 Baton is the most compact addition to Olight's versatile and dependable S series of flashlights. At less than 3 inches long, this light packs a punch, capable of generating up to 400 lumens in high mode from the latest CREE XM-L2 LED. A large blue side switch cycles through high, medium, low, and moonlight modes, and can access the strobe with a simple double-tap. The S10 can be powered by a single CR123 or rechargeable RCR123 cell and can run for 15 days under moonlight mode. Durable anodized aluminum, a stainless steel head ring, and an ultra-strong pocket clip mean you can feel comfortable taking this light anywhere. A strong magnet in the tail of the light allows for mounting onto any ferrous surface, adding to this unique light's extreme versatility.
Features:
Moonlight Mode is accessed directly when the flashlight is off
o Continue holding switch when in Moonlight Mode to access Lockout Mode
Double click the on/off button to activate strobe mode
Equipped with auto memory function and a side switch
Magnetic tail allows the flashlight to be attached vertically on any magnetic surface
Two-direction invertible pocket clip
Stainless steel head ring
Flat tail cap allows convenient tail standing
High efficiency constant current drive circuit
Specifications:
LED: CREE XM-L2
Runs on: 1x CR123A or 1x RCR123(Batteries NOT included)
Output mode/Runtime*:
o High: 400 lumens / 1.25 hrs
o Mid: 85 lumens / 7.5 hrs
o Low: 5 lumens / 108 hrs
o Moonlight: .5 lumens/360 hrs
Peak Beam Intensity: 2700cd
Max beam distance: 104m
Dimensions:
o Length: 2.77" (70.5mm)
o Diameter: .9" (23mm)
Weight: 1.48 .oz (42g) (excluding battery)
Olight i3S EOS, Red, 80 lm, Asking $22 shipped
The Olight i3 Multi-Color flashlights comes in miniature sizes as the best elaboration for the EDC flashlight. The flashlight is equipped with its respective single AAA battery. With three output levels of Low-Med-High, a removable clip, and its keychain hole, the i3 Multi-Color is convenient every day and everywhere. The flashlight is suitable for small area lighting: dark stairs, corridor lighting, searching for smaller objects, and recognizing small printings. Features: Material - Aluminum body with anti-scratching type III hard anodizing finish. Powersource - 1 x AAA Battery. Bulb - CREE XP-G2 LED. Output - Hi: 80 lm Lo: 5 lm. Run Time - Hi: 6 hrs Lo: 6 hrs. Sumbersible - IPX-8 Rated Waterproof (2M for 1 Hour). Carry System - Keychain or pocket clip included. Battery Included
First "I'll take it" applies
PAYPAL, USPS Money Orders (or personal checks if weve done business before)
Will only ship to USA
No Trades at this time
Any questions please email me at empty5853@yahoo.com.
Thanks for looking.
Mark T.
Features:
Specifications:
LED: CREE XM-L2
Dimensions:
Thanks for looking.
Mark T.
