Uneven/curved grind lines can be caused by a number of things, but the main culprits are usually as follows:
1: uneven grinding pressure, or leaning into the corner/side of the belt/platen. Watch your sparks, they'll tell you where your belt is cutting.
2: the stock is not flat: if the bar your grinding on is bowed/warped at all, and you're grinding flat on a a platen, you're not going to be contacting the belt evenly, and this will cause the grind to curve up or down based on whether you are grinding the concave side or convex side.
3: dull belts: if you have sharper/more grit on one side, and are dull on the other, this will affect your material removal rate, and it will not be even or flat. Change to a fresh sharp belt and see if this helps.
Those are probably the 3 most common, though flatness of your table/workrest, and/or your platen can factor in as well.
My opinions on jigs have evolved somewhat over the years, but one thing will always be true: They won't grind the knife for you. Some jigs are better than others, but they all have their limitations, and really (at best) will only take the guess work out of ONE plane of grinding. You still have to think about the other two planes. I encourage any maker to learn how to free hand grind, even before using jigs, if possible, as you get a much clearer picture of what the mechanics of grinding actually are, as well as being able to understand more about the limitations of jigs.
