- Sep 22, 2009
Again, its not the arrow, its the indian...
LOL. That phrase is just perfect. :thumbup:
I thoroughly intend to use this as a mantra while I'm trying, yet again, to pull off fire by friction. Hope you don't mind.
Are there easier or more effective ways of making fire by friction? Other than the bow drill obviously.
Maybe a fire piston???
I don't really know, as I have zero experience with them.
that's compression. i've tried making a couple, and it's never worked out.
...Another friction method I have used is the Bamboo Fire Saw. Good technique.
Yes, but if I remember my high school physics, heat generated by compressing air is caused by molecular friction...or then again (high school was sooo long ago) I may be speaking out of my azz again...
As for the reason behind building for this way: As already been mentioned it's to truly learn how to build fires under the worst of conditions. Even with a Bic lighter sometimes building fire is not that easy. Learning the basics first gives you knowledge to make more modern methods easier. Fire with a Ferro rod, IMO, is just too damn easy. Try true flint and steel or friction if you really want to learn the real basics.
Do you use charcloth at all or is that "cheating"?
I suggest starting with nothing-only with what you can find. Ideally you want to be able to build a fire with only materials and tinder you can get off the land. Really makes you appreciate what firebuilding tools you do bring. Also teaches you the importance of fire BUILDING techniques-collecting and prepping the tinder and wood or other fuel sources (around here I find more cow crap than woody plants)
