- Feb 29, 2008
nothine like popcorn's mix....but hes gone now
Don't leave bottle water in the sun to disinfect unless you're sure it will get very very hot...or you'll create a petting zoo in the bottle. Bugs die in very hot water, but breed like crazy in warm water. Not all bacteria dies at the same temp either. 60 C seems very low.
I believe it's the UV light that does the disinfection, not the temperature. (Technically, I think oxygen radicals formed by the uv interrupt cell metabolism, but that may be more info than folks need/want to know.)
Not trying to be disrespectful or anything of the like but I really don't think that UV is practical in the area of primitive water purification.
I do believe that trapping and containing rainwater holds some great possibilities. Also at this point I do believe that gravity--Carbon type water filters probably are the best method to start out with until one attains more primitive water treatment skills.
I've heard for years that sand and rocks both are your friends when it comes to purification. This is a subject I'm going to put a lot of priority on because I do believe that water is in the top 3 main priorities in any survival situation.
I'm going to scan some past magazines today and tonight on the subject. I do like the feedback I'm getting thus far. I'm still open to any input on the subject of primitive or basic water purification. >> JD
Right, UV will inactivate (neuter, not kill) bacteria, viruses, etc. at the correct wavelength(s). Makes a mess of their DNA so they can't breed. If the sun will cooperate and focus an intense beam of UV at the correct wavelength (UV 254 is what I'm familiar with) then you're good. The sun isn't going to do that for you, you'd need some sort of reactor to generate the required UV intensity.
Hi JCavSD,
I understand that UV-C (the spectrum you're working within) is the most germicidal of the three, but plastics found in bottles block this wavelength. I believe that SODIS relies on UV-A and UV-B, which apparently aren't effected by the plastics over many hrs of exposure. Whilst not as germicidal, they still do the trick apparently.
This is going from memory.
Where are you getting your information?works extremely well
SODIS is being aggressively taught around arid regions for water purification because it works extremely well, is easily taught to villagers with readily available containers. It takes very little UV from the sun to work, as the UV index has gotten much higher the last 10 years.
I'm completely in the dark as to how to use UV rays in a setting with little access to tools and such.
There's plenty of info on the net. The idea is to put water in clear plastic bottles or bags and expose it to direct sunlight for six hours. That kills or cripples some of the germs in it and makes the water less likely to cause diarrhea (which is a major killer in third world countries) and widespread adoption could save a lot of lives, but it's not 100% sterilization.
Search keyword SODIS for more info.
Well, just to humor my pet peeve, be cautious of any information or product that uses the term purification. Usually marketing BS or someone not familiar with water treatment. Disinfection and purification are not the same, and no product that any of us are likely to ever use will purify the water. That goes for warm bag water too. Oy!
