- Apr 19, 1999
Andrew, I've seen an axehead tied up with common lashings within a partially split handle. The head was grooved somewhat and it appeared to be quite sturdy.
does anyone know a good knot to tie a big rock on the end of a stick to make an axe or hammer?
Fascinating stuff, BikerMike. As you know, I'm with you in my skepticism that I could put an atlatl or sling to good-enough use quickly enough to keep fed on wild game. I'm curious: what's the deal with that double bow setup you show in your second picture? What's it do? How do you do it? Advantage?
Oh: and how do you process the bow wood so that it retains suppleness? Like, how do you dry it, oil it (or whatever), etc.?
Thanks for the compliment. Heres another set up that I made, mostly from things I harvested, found or traded for.
When I first started learning primitive skills I had a "survival" mind set. After gaining some proficiency in primitive tools and weapons I stopped thinking of having to survive in the bush and started to look at it as going home. Everything I need I can find or make.
I could get fat off the land with my bow and traps. With an Atlatl I'd loose weight. With a sling I'd probably hurt my self.
Lol, that's clever. But if I remember correctly, the original boomerangs DIDN'T come back; they were just really heavy and were thrown like a rabbit stick. Eventually, some intelligent fellow figured out how to retrieve it with less walking/searching.
Absolutely beautiful work. You should have your own site where your admirers could linger, and drool, over your craftsmanship...and maybe learn a thing or two while we were at it.
By biker, do you mean "Biker" or "cyclist?"
