probably not in the right place, but...
hello everybody, i'm very new here, and to fixed blades. i was drooling over some busses when i found their more affordable relative in scrap yard knives. i think i'll get a scrapper 6, but what's a zero edge, and will it make the LE better than the regular scrapper 6? thanks
a zero edge, as i understand it (and i may be completely wrong:D ), is most knives have a secondary grind where the edge comes to a point. a zero grind does not have this secondary grind and in the case of the scrapyard the edge appears to have been ground right from the spine to the edge. if you see the two next two each other it is obvious. i probably lack the vocabulary to explain this properly, but gave it a shot anyway. hope i helped.
the scrapper 6 is a full flat grind fixed blade.
with the full flat grind, there are 2 seperate bevels on the knife, the main primary bevel that makes up most of the visible surface of the knife, and the cutting edge bevel, wich is what you grind on to sharpen the knife.
on most knives, these are 2 completely seperate flat surfaces, that have a line that meets at an obtuse angle where the primary bevel meets the cutting edge bevel.
on a zero ground knife, wich can mean one of 2 things, there is no angle between the two, it is convex ground so that it is a smooth round transition.
that is one type, where it is convexed for a smooth transition. the other is a puuko style zero edge grind, wich is where the entire primary bevel is sharpened to sharpen the edge of the knife. sort of as though the cutting edge bevel was extended out much farther then normal.
on busse knives, you'll see the convexed type of "zero edge".
KAAK.... please oooo please kill the clowns in your sig line... if you only knew how much I dispise clowns... it makes me want to shoot the monitor just by looking at those pics :D
Just my 2 centavos, but a clown looks ... just clownish looking. :o
But sooo much better than Zardoz (Zed.) Never did like diapers even as a newborn. :D
Did someone say something about teeth and diapers?
ahh... excellent. thank you guys for all the information...and, uh, and the disturbing baby pic...
Got a smog? :D :p
Hmmm... I may be onto something here.:D :eek: :rolleyes: ;)
