^ very nice (poor Maisy)
I'm 99% sure I need to add weight to my dips, at what point should a guy (or gal) think about adding weight to pull/chinups? I'm probably a little shy of 20 for a max, typically doing sets of 12, sometimes a little higher (sometimes a little lower)
Depends entirely on what you're working toward. I rarely added weight on chins, usually had someone stand over me and help me get started with real heavy lat pulldowns if I wanted more resistance there. I've added up to 65lbs. on dips when I was younger, but will not do so again. Dips can be rough on the shoulders and elbows if you go past parallel. Lots of torque on the joints.I'm 99% sure I need to add weight to my dips, at what point should a guy (or gal) think about adding weight to pull/chinups? I'm probably a little shy of 20 for a max, typically doing sets of 12, sometimes a little higher (sometimes a little lower)
I guess whatever keeps you in the rep range you want, but doesn't sacrifice form. When you start having to speed up to maintain momentum to complete reps, curving your back and lowering your head, or bottoming out because you can't control the descent, you've gone too far. This isn't the exercise you want to cheat on, IMO, and adding weight should be done gradually.
I googled "proper dip form", and this is pretty good:
http://www.youtube.com/watch?v=Sr1svs0wliI
turns out the gym has a 25# vestI used it w/ pulls/chins and dips- it knocked my reps back by ~ 25%, I think I'll use the vest for a week or two, go back to no vest and then just mix it up a bit from there
in other news, by sprints didn't go so well on Thursday- my plan was to mix the sprints up w/ some 220's, 440's and 100's- did my warmup per usual, did 220's w/o any problem, on my first 100 I strained a groin muscle about 3/4 of the way in- clearly I was pushing too hard, another lesson learned the hard wayI was able to jog on it for ~ 1.5 miles afterwards, but it's more sore today than yesterday
I'll see how I feel tomorrow, but the running might be out for awhile- the sprints are definitely out for awhile
Sorry brother haven;t been on in a few days
http://www.spartanrace.com/
Out here we have a whole series from which to choose: http://www.camppendletonraces.com/Sorry brother haven;t been on in a few days
