- Dec 20, 2005
I bought some 1/8" thick CPM S30V from Jantz Supply recently and it seems like it left the mill hardened in certain areas. Anyone else experienced this?
I drilled a 3/16" and a 1/4" hole, then tried a 5/16", the drill bit squeeled half way through the steel and ended up rounded off. I tried this using 3 (2 HSS and 1 cobalt) drill bits before eventually getting through -but killed all the bits.
I've worked with CPM S30V, D2, ATS-34 and never had a problem before. The speed on the drill press is set at the slowest and I haven't had to replace a single drill bit before.
Anyone have any batches of CPM S30V that had certain spots that they just couldn't drill? Or is it just me? I used a lot of precision ground D2 last year and never had a problem.
