A couple of days ago I dropped my D2 Millie on the stone kitchen floor, from 3 feet high. The knife was open, and landed tail first. No damage to the blade on the bounces, but something started to rattle in it, when shaken.
A closer look revealed that the lanyard metal "tunnel" had released from the one of the G10 scales, and the metal spacer that surrounds the "tunnel" was loose, thereby rattling when shaken. The scales, if not pressed by hand, are perhaps about half a milimeter further apart than they should be, and this creates the play for the rattle.
I tried punching the hole with a philips screwdriver, to widen it's opening and press-fit it into the G10, but it doesn't hold. Next on my list to try is a drop of superglue, but I'm a bit concerned that if I overdo it, the scales may be permanentely glued through the pole, making later disassembly impossible.
Any suggestions? This is the first time I've had a problem with a Millie, and sending it to the factory is totally out of the question.
As it is, function is not affected at all, but the rattling is kind of annoying... Dang, my brand new D2...
