- Nov 23, 2013
I've been working on a drop point hunter and decided to use moose antler scales for the handle. But I had fits with the scales warping and twisting on me as I worked it. Any way to avoid that? Is there a good fix when it happens? Yes, I was using a fresh 80 grit belt to shape it, but it still got warm very fast. I tried grinding a scrap and dipping in water to cool but it warped like mad. So I tried an impromptu "plate quench" to cool it. Every 15 seconds or so I would press the ground side to a cold steel plate to cool it. That helped a lot, but it still tried to twist into a shallow corkscrew.
The other problem I had was with the brass pins. In order to correct the mild warp that I couldn't sand out, I ended up with too long of pins that I over peened in a somewhat successful attempt to flatten the scales. I ended up sanding them down very carefully, but I ended up with irregular shaped (and out of round) pins. Anything I could do next time to make the pins look neater, especially when dealing with a textured surface like antler?
Considering all the trouble I had with the scales and pins, I think this one turned out pretty good. What do you think? As usual, my plunges aren't even (not sure if I'll ever figure out that one) and the handle is a bit on the short side @ 3.8". I wanted 4.5, but I forgot to measure until it was too late to draw out the tang any more.
