It sounds like you've got something jamming up the tang, possibly a burr somewhere. Since it's closed, take a look at the round end of the tang, is it smooth or is there any kind of gouge in it? If that's the case something's likely embedded in the spring. If it's smooth, then the problem's likely against the scales. If you look into the knife, are there any curved scratches in the scales on either side of where the tang travels? Are the front edges of the scales (the top part where the blade drops in) smooth at the tang area, or can you catch a fingernail under it?
Eric
That is really a valid point.
I just bought an old Kabar Barlow that was in excellent shape. It looked almost new and the price was right. So why did it look new and why was it priced so aggressively?
The pen blade was binding very badly, and with a ton of effort and split nail on my part I got it open. The used knife dealer (this is at a gun show) told me he thought all it needed was a bit of oil and it would snap like a new knife, easy to open and easy to close. I got a helluva laugh out of that, and since he knew better, even he laughed. He knocked down the price a bit and I bought it.
I had to open it with a pair of pliers, when I got it home. I oiled it up, worked it a bit, and while it worked better, it was still pretty awful. While peering into the insides of the knife with the offending blade about half open, I saw little burrs on both sides of the kick of the pen blade. I got out a diamond file and rounded them off. That made an immediate difference.
I flushed it out with brake cleaning spray, and put about 3 drops of machine oil and worked the blade back and forth. Lots of gray metal powder came out of the pivot joint, and I oiled and worked until the oil stayed clear.
On careful examination you can see the marks where the burrs were literally cutting into the liners, and when they did the swarf was stuck in the pivot joint.
The knife is great now, and while the pen is a bit stiff, it opens fairly easily (and quite smooth) with a fingernail.
Robert
