Just heat treated some thicker 3v bush knives One was 5/16" thick the other was just shy of 3/8". I sealed in heat treat foil.
took to 1500f soak for 20min then fast ramp to 1985F soak 30min. I then pulled from oven and plate quenched while blowing compressed air into the foil pack witch I cut the end off while clamped in plates, rockwell tested one and was 61rc.
soaked in Liq N02 for 20hr, then I tempered them at 425f twice for 3hr and now they are testing at 58-59rc
checked the toughness of the test blade by tapping on piece of mild steel flat bar and it started chipping out.
I was expecting alot more toughness from an un-sharpened edge at .025"
I'm wondering if the plates are not cooling it down fast enough and go to and oil quench for the thicker stuff.
going to try tempering again at 500F temper and check toughness, will up date,
Any suggestions on a proper low temper 3v recipe would be appreciated!
