- Nov 2, 2010
Summary: a blade failed to harden. What do I need to do before another attempt at hardening?
I have a 1095 blade, about 6" long, 0.125" thick.
What I did:
Heat to 1475F, hold 10 minutes (kiln).
Preheat a gallon of vegetable oil using a red hot rebar quench. Temperature at quench is unknown.
Quench, slowly agitating up-down and slicing.
A file still grabbed, but I cleaned off most of the decarb and tried a temper cycle at 400F for 2 hours. Maybe the RA would convert to tons of fresh Martensite, he hoped.
The file was still attacking it, so it failed to harden.
After some research, I discovered:
1) As a beginner, I should have avoided 1095.
2) Parks fast quench oil is preferred, but water can work, with increased risk of cracking/warping.
What I plan:
Repeat the same steps, except using a 150F water quench.
Getting $150 of oil for one knife may be a bit steep for this stage of my tinkering.
Questions:
Is there anything that needs to be done before repeating the hardening attempt? Like normalizing or otherwise?
What would you do different than my plan?
Is a brine better than regular water? I'm under the impression that it would cool it faster, but that may be too fast.
What I did:
What I plan:
Questions:
