Purchase a high quality re-saw blade for your bandsaw. Tune up all the settings on the saw (wheels, guide blocks, etc); there are some good videos for this on YouTube. These two things will make a world of difference. Make or purchase a point fence.
If only cutting for small stock (knife scales and such) you could try a high quality hand rip saw.
For flattening a 12 inch disc or 4x36 belt sander would be a good investment. Finish with sand paper on granite or glass. If you have a good router, you could make a sled and flatten with a wide bowl bit.
Once again, if small stock, a large high quality rasp would work. Finish with paper on flat surface as described above.
As a side note, if your hand planes are not cutting well they are either not sharp enough or not adjusted properly, likely both. Getting planes set up just right is much more of an art than using them.
