I can see pretty easily up to about 400 grit. After that, I usually make a couple trips to the buffer as I'm sanding up to 800-1200. Buffing lightly makes them stand out pretty well. Some woods are harder to see than others.
You been hangin round my shop?A quick buff, then you see what needs more work, then you try to use the buffer to "blend" out 220 grit scratches on your 400 grit handle, then you ignore it and try to get it out with the same 400 grit you have been using instead of going back a grit in that area like you should, then after spending 2X as much time as it would have taken you to do it right you go back a grit like you know you should have to begin with.
You been hangin round my shop?![]()
This sounds so familiarA quick buff, then you see what needs more work, then you try to use the buffer to "blend" out 220 grit scratches on your 400 grit handle, then you ignore it and try to get it out with the same 400 grit you have been using instead of going back a grit in that area like you should, then after spending 2X as much time as it would have taken you to do it right you go back a grit like you know you should have to begin with.
Just do it by hand and look at what the paper does. It will tell you when a grit size is done after a while.
As a rule of thumb a guy should double your number when stepping up. Your jump from 400 to 1000 is a pretty big jump, maybe part of the problem?
