Project #10: Push Dagger
I finally remembered to scan the image from the book.
Here is a sketch of what I was talking about on how to fit a guard and handle on such a knife:
Ah, I get it now. Thanks for the explanation. I'm pretty committed to the integral guard on this one, but I can definitely see the benefit of your approach. I'll go that route on the next one I make (using the leftover piece of sharks tooth damascus I have).
The biggest advantage over the integral mode is the ability to finish the bevels straight and smooth without the guard in the way. Once the blade is done, the hardware is fitted and the knife is assembled.
Exactly what I was thinking. I'll admit it has been challenging using my approach, and the results are not perfect. I'm generally pleased with the way it's going, but your way would definitely be easier and more professional.
I had another thought about your approach too... if the tang was thin enough, you could put a cylindrical bolster around it to act as a brace for the guard and give the fingers a smooth round surface to contact instead of the tang. I think that is how they made the one pictured in the book. My only problem with that is it would result in the tang being very small in the handle. When I look at the picture from the book I think I see a screw in the base of the handle, and I wouldn't want that protruding on my version.
Not much to report besides cleaning up the surfaces. Still a way to go before I send it off to HT. Certainly not as fancy as the one posted by Chuck.
Reshaped the tang a bit and did a trial fitting in a stag antler piece. It feels very natural in the hand, but doesn't look as cool as I'd like. At least I can take some clues about the shape I need to aim for.
This morning I had an idea for the handle. I remembered that the Lignum Vitae had a curvature in the banding that approximated the curve of the antler piece. I also remembered that this wood is one of the toughest around, so there should not be any problems with chipping or breakage during assemble (as I had with another wood block I used for a sample handle).
So I traced the outline of the antler on the piece that most closely matched the curve, cut it out and drilled out the channel to the proper depth. I feel good about this so far, so I'll likely use this as my solution. The ink line above the banding shows the channel depth... enough to give me room to shape the top and still maintain about equal parts of dark and light in the handle.
Once I get this shaped properly (and decide whether or not to use corby bolts in addition to glue), I'll send the blade off for HT. Right now I'm leaning toward no bolts.
Last photos before it goes off for heat treatment. I ground down a high spot on one side of the blade, got the handle piece sanded down to size and fitting well, skinnied out the post behind the guard, and did a lot of general sanding.
The blade just came back from Peter's, and I'm cleaning it up now. It occurs to me that for the first time I have three projects running simultaneously. I'm going to focus on finishing this one before doing anything more on the others.
- Greg
I love my ColdSteel safekeeper 1 (hard to find now adays). It's blade is humungus compared to the safe keeper2 which is the same size as the safemaker1. Either way, I suggest a longer blade lenght of at least 4-5 inchs. A 3 inch blade may not reach someones heart if you decide you have to punch someone in the chest...
Now there's a gruesome thought.
Agreed. This isn't the place for it, but 3" would accomplish that anyways.
Any update on your PD? Still out at heat treat I would guess. How are you planning to finish the handle?
Back from heat treat as of yesterday. It came back with a beautiful blued finish. Pity I had to sand it off. My plan it to keep this one simple. No elaborate carving in the handle, no additional detailing for the metal. I'm even going to hide the makers mark on the tang, buried in the handle. I thought about other placements, but that one makes the most sense to me. I'm going for simplicity with this one because it seems to fit. The pictures I posted on May 14 will be essentially the final form, with just a bit more sanding and shaping done once the handle is permanently fitted.
It's looking nice and sleek.
Will you pin the handle?
I assume you'll also hand finish the blade.
Personaly I like it if you can see the lines of the last finish go from the ricasso to the tip, folowing the edge. So not in a straight line but so that where the blade has a bellie, the hand finnish will follow it.
To me details like that give a knife (or other object) charm
