Forge in fire by George Arapoglou, on Flickr
forge home made by George Arapoglou, on FlickrAny high temperature refractory coating will work. Call a furnace company and ask what they carry or who they recommend as a supplier.
You want a "monolithic Refractory". That is a powder you mix with water to make a cement like mixture. It is sometimes referred to as "Castable refractory" or "Plastic refractory".
Many large hardware stores sell it in tubs for fireplace and furnace repair.
Others refractory brand names are :
ATP (ATP-641 is a populate refractory type )
Furnascote
Plibrico (they make plistix, which is like ITC-100)
Rutland's
Meeco
Hurcules
Red-Devil
nevermind what ?
I think the two "non responses" are based on you wanting to make a forge and make knives, but won't/can't make a simple venturi burner.
There is nothing I can think of simpler than a venturi burner. It is a piece of 3/4" or 1" (20mm or 25mm) plumbing pipe and a couple fittings plus a 1/4 (6mm) valve and connection for the propane hose. It probably costs less than 30 Euro to make a burner. You might be able to It can be done with very simple welding or no special tools ( a pipe wrench and a drill). If you can tap a hole ( or get it tapped by a friend) using a MIG tip (#30) makes it even simpler.
Some of the stuff from your weed burner can be used.Any regulator that delivers 15PSI or more will work. A welding gas regulator will do fine. The fitting is the same as acetylene. A BBQ regulator usually won't work, as it won't deliver enough propane to run a burner.
You can buy also burners that are guaranteed to work almost everywhere. There are kits and finished from places like HighTempToolsandRefractory.com and really low priced burners from Atlas Knife and Tool company - http://www.atlasknife.com/.
Many of these folks will ship overseas. I am sure there are other sources in Europe. I would look at some of the European knife supply companies.
Do some searches and look at some videos. I am sure it will make sense.
I was going to recommend an atlas burner, but realized it was going to be more difficult to purchase overseas.
