- Jul 13, 2009
Thank you guys for all of the helpful info. Don brought up the idea of efficiency of a propane forge. What are some ways to make a forge more efficient with propane usage. Also would wrapping the propane tank in insulation help with the freezing issue?
Does a forge need a hole(vent) in both front and back, or just front?
You don't want to insulate the tank, exactly the opposite
You need the tank to absorb heat from the surrounding air.
As the propane changes from a liquid to a gas, it absorbs heat
The whole idea of refrigeration is based on that.
In theory you need to add heat to the tank, but that's unsafe
You can't keep the cylinder inside a heated area, it belongs outside
You can't add heat to the cylinder, over heating can cause high pressure to overcome the pressure relief valve and it exhausts all that flammable gas, or the cylinder explodes
hence the need for that cylinder or tank to be outside.
They call that failure a BLEVE
Boiling liquid expanding vapour explosion -
http://en.wikipedia.org/wiki/Boiling_liquid_expanding_vapor_explosion
The solution is a bigger tank as everyone here has mentioned
As the tank gets larger, the temperature difference as it gets used is less due to the mass and large heat capacity
You will see some folks try to put a little bbq tank is a tub of water, which increases the heat capacity but that's a real pita
You will see some folks try to put heating pads and such under tanks, but I think that's too risky
If you can't do one large tank, you can use manifold and connect several together.
