- Jun 20, 2007
This thread has arisen out of a discussion on another forum over quench procedures for 1080. While I am still new at the knife business and still learning I felt that I had the quench procedure correct in my mind. However after discussion with this person I find myself scratching my head and asking if I am correct in my procedures. I am not trying to start a war over procedures I am just looking for guidance as to what works and why!!!!!!!
I am going to present the two different views here and not reveal my thoughts so as not to influence your decision in this discussion.
1. When quenching a blade made of 1080 in oil. You should......
A. Plunge the blade vertically, quickly all the way to the hilt, to get an even hardening.
B. Lower blade some what horizontally allowing the blades edge, to contact the quench oil with a two second count and then submerging entire blade.
C. None of the above and you must explain what you feel the correct procedure is for an oil quench and why.
2. When quenching a blade in water or brine. You should......
B. Lower blade some what horizontally allowing the blades edge, to contact the water or brine with a two second count and then submerging entire blade.
C. None of the above and you must explain what you feel the correct procedure is for a water or brine quench and why.
I am trying to make this simple, however if your ideas don't fit into the questions posed, please feel free to share your thoughts. All I ask is for you to give a little insight into what supports your procedures on quenching in different mediums!
