- Apr 13, 2007
I second that sentiment! Very informative!Thanks for all your time spent here with us Jerker.
You've given us a lot of valuable information. :thumbup:
:thumbup::thumbup:
Jerker, I am not sure how this will come across in print, but I think I know what you are saying. It makes me think of how people use things according to how they percieve them.
Think of a Sebenza. The large majority of owners use them for jobs that most people could use any tool for. Because of their price, the knives are used VERY lightly. It makes me think that a steel could be graded as an expensive, specialty steel, and then people would percieve that it's use would need to be commensurate with the way it is graded.
The steel could be the same basic composition, but it's price and description would suggest something other than general use. Then, heat treat specs could be given for that steel that would push the line a little.
As I understand, there are certain Spyderco knives designed for a thin edge and lighter cutting tasks. Those who buy those knives do so with the realization that more care will be required in use. Kind of like the SG2 Kershaws.
If a steel was graded/priced differently, wouldn't this have the same effect, even if the formula was basically the same? One steel could have a more forgiving heat treat, and another, with a different price, could carry a higher end, more rigid heat treat sequence, though both are of very similiar composition?
In my experiences the ZDP-189 has a lot better wear resistance then
the S30V. Not that S30V is bad in any means. I have many knives in
S30V and I think it's a great steel. For me it just comes down to what
I plan on doing when I pick a certain knife with a certain steel. If I plan
on cutting a lot where wear resistance is an issue, I'll reach for the ZDP.
But for the most part in every day use, the 13C26 just does the trick for
me. It takes a fine edge, holds it pretty well and it's easy to bring back a
scary sharp edge on. I usually take my edges down to around 12 degrees
per side, and even at that angle 13C26 holds a great edge as long as I'm not
cutting something very abrasive.
