marrenmiller
Basic Member
- Apr 6, 2017
I've done what you're asking and have never encountered any thickening immediately before the edge on any hollow grind I've owned, including the Umnumzaan I just bought. I don't think that's nearly as common as you're suggesting.No it’s not a sloppy production error. It is by design so that way once the material “jumps” over the thicker edge it is no longer in contact with the sides of the blade. The David Boye hollow grind will have the material always be in contact.
You can test it yourself. Pinch the blade on either side and pull your fingers down past the edge until the blade slips out of your pinched fingers. You will feel that little “speed bump” yiur fingers go over right before they pass over thr edge. So basically you are pinching in the hollows on either side of the blade and slowly pulling your knife upwards out of the pinch.
Also, how does anybody here know for certain what Buck actually intended to do with their hollow grinds?
Do you use micrometers to measure this supposed increase in thickness?
