Prybars that can cut
Give me a long enough lever and I"ll move the world.
Shaving hair, slicing paper or cutting paracord are not useful for evaluating slicing capability. You could sharpen a literal pry bar & it would probably do quite well on all three.
To test how well a blades slices, you can do things like cutting onions into thin slices, or slicing though a block of cheese. Slicing through thick, double or tipple walled cardboard works well too.
Fair point
If you want the best to slice thru thick materials , you need thin .
But wider blades can be fairly thick at the spine and have enough depth to be fairly thin nearer the edge .
So , knives like Cold Steel 4 Max can be overbuilt and still useful cutters . :cool:
Tops Steel Eagle slices way better than 1/4" blade stock with a low saber grind should.
I know Alone Alone would most likely agree. :)
Disclaimer - I have thinned out the edges a couple of DPS, however.
Yup, Alone definitely agrees.
Best knives I've ever owned, hands down...
Whenever I read a post in which someone says that thick knives won't cut, these ^^^ are the first blades I think of. Are they filet knives? Absolutely not. However, they've done everything I've ever asked of 'em.
While I don't disagree that many thick knives aren't necessarily stellar cutters, these knives are definitely an exception to that rule.
This is my Wilson Tactical model 25, it was my daily-carry knife for many years. I used it at my shipping job, prying open packing crates, as well as cutting a wide variety of things like rope, twine, plastic compression straps, etc.
Then I used it in construction, specifically while inspecting old houses that I was going to remodel. I'd use it to pry old plaster and wood paneling off of walls, pry away cabinetry, and various other such tasks to see what was behind them, trace electrical wires, plumbing, etc.
I've also used it for other prying jobs. And it's sharp enough to shave hair.
The blade is 5" long, 7/32nds" thick, D2 steel. A little brute of a knife.
Big relatively thick heavy Kukris have been used very effectively for everyday household chores and food processing for a long time in places like Nepal I read.
I did recently get a crkt siwi. Which I think does that concept quite well.
My theory was I carry a folder for cutting tasks. I wanted a fixed blade for jobs my folder couldn't do.
And it is going on a little bug out kit i am playing around with. And so just in case I need to can open a car or stab a hobo or something. It has those sort of options.
