PSK vs RAK
Alright, I'm looking for a second, third, forth and so on oppinion of which knife to go with here. After much consideration I have narrowed my search down to one of these knives.
1.) Camillus U.S. Pilot Survival Knife (with metel tipped sheath) [$35]
• Overall Length: 9 ½’’ (24.1cm)
• Blade: 5’’ (12.7cm)
• High carbon 1095 steel blade
• Parkerized phosphate anti-corrosion coating
• Weight: 1.4 lbs
• Saw back edge
• Hardened hexagonal steel butt for hammering
• Steel guard pierced with 2 holes for lacing on shaft to make a spear
• Built-up leather washer handle
• Leather sheath with protected metal tip
• Riveted for strength
• Carborundum stone in snap closing pocket
• Leg tie cord.
• Made by Camillus Cutlery.
Shipping Weight: 0.81 lb / 0.37 kg
2.) RANGER KNIVES® ASSAULT KNIFE R.A.K [$70]
• Length: Overall, 117/8"
• Blade Length- 5¾"
• Thickness: 3/16”
• Steel: 1095
• Made in USA.
Shipping Weight: 0.50 lb / 0.23 kg
I am using this knife primarily in a backpacking role. To me it seems that the PSK is a heavier knife, which would help in choping. I like the saw back on it, since I can save some wear on the blade by utalizing this feature instead of the blade all the time. Also the large pummel will allow me to drive tent stakes into the ground. The fact that the SAK comes with a stone and the RAK does not isn't really an issue since I can back pack a stone seperately. From what I have read the Ranger knife will hold a sharper edge than the PSK and it will hold it longer. The ranger knife is better ballanced as a thower, but I'm not sure how often if ever that will be relevant. Basically what I'm looking for here is if you were going on a week long or a month long backpacking venture, which one would you take with you and what would the advantage be in taking one over the other.
Thanks in advance for everyones thoughts.
Go for the Ranger knife . I have a RAK and a Camallius psk .
I use the RAK all the time , the last time i looked at the Camillus it was starting to rust i just dont use it since i got the RAK .
I'm starting to lean towards the Ranger Knife, now. Thanks for the help, gents, glad to see someone owned both and could give his insight.
Contact justin and you can order a RAK to your specs. yeah it's gonna cost more, but it's worth it. been itching to get a RAK in 5160, flat ground, with micarta scales for some time now...:D
