- Jan 28, 2005
Going to order a 3HP 3PH 1740 and VFD. I'm going to hook it up to my 2x42 with pulleys till I can save up for a full size grinder. I'm decent on the 2x42 now, so figure I'll get a good motor and VFD that will give me more speed/power control over it. Then I'll be able to move over to a full size grinder when cash comes available.
Anyway, have a few questions before I order parts:
1.Pulleys:
A. I know what inside dia. sizes, but what outside dia should I get for the motor side and the grinder side. Again, I'll have a VFD so no step pulley needed.
B. Also, what v-belt size/spec should be used? 24" A Series? (as long as it matches the pulleys)?
2. VFD: (KBAC-29 3HP NEMA 4X VFD 230VAC 1PH INPUT 10001)
A. I see options for the VFD and wondered if I should add any of these to the order, if they are important:
1. On/Off AC Line Switch:
a. Yes
b. No
2. Forward-Stop-Reverse Switch:
a. Yes
b. No
3. Signal Isolator Options:
a. Signal Isolator with Auto/Manual Switch
b. Signal Isolator without Auto/Manual Switch
4. Liquidtight Fittings:
a. Yes
b. No
Thanks guys!
Thanks,
John
1.Pulleys:
a. Yes
b. No
a. Yes
b. No
a. Yes
b. No
Thanks guys!
Thanks,
John
