- Jun 20, 2007
Thanks for sharing your R&D with us Dixieblade57. (Sorry, my participation on BF is such that I've missed your name.) These open explorations are helpful to many of us.
I always wonder about how hot water heater elements work. Do they heat by just being fully on (high heat temp) and stay fully on until the liquid reaches the target temp when they are shut off via the thermostat? If so, wouldn't that accelerate oil degradation? I believe I've read quenchent specs that refer to heating temp specifications cautioning using too high a heat. Maybe it's a mute point because hot water heating element heat with low temps? I wonder what folks thoughts are on this. Thanks, Phil
Phil, I am not the smartest fellar out their but will try and address what you are talking about. My idea for the element is that it preheats to the needed temp for quenching. In this case I think I will run a thermostat on the heating element, otherwise yes as long as their is power there it continues to heat, (by being fully on), and I would have to be cautious and not let the heat build to much while using the element in the quench tank. A replacement thermostat can be bought at the hardware, for around $11.00, so that is a small investment.
I will also install a thermometer to monitor the overall temp of the oil, as each quench will cause the heat to build in the oil. I may invest in one that will alarm when the temp gets over a certain degree. My son in law is a electronic and computer wiz kid so he can help out there. At present time I am not building enough knives that I feel I will have to install a cooler but I plan on making a provision for one so if at a later date I feel the need it will be only a matter of adding it into the system.
Because I believe you are correct in stating that overheating is one of the causes of degradation of the oil no matter what kind it is.
