Everything dies before boiling, but if we get it to a rolling boil, we can be sure.
Interesting table here on temperatures to kill nasties: http://www.ziemia.org/sodis.php
F = C x 1.8 + 32 so 60C = 140 F. Water boils at 212 F or 100 C.
Water is gtg once it boils. From some published material you would think they were trying to stew a chicken. Mac
Because the botulism toxin is destroyed by high temperatures, persons who eat home-canned foods should consider boiling the food for 10 minutes before eating it to ensure safety.
Good to know.That's right, with all the cell culture work and primary cell isolation I do in lab, things get pretty messed up if you vary the temp even a little beyond 37C. At least for mammalian cells. I don't think even the bacterium Thermus aquaticus, known for its resistance to high temps, can survive 100C.
However some bacteria like Clostridium botulinum (causes botulism, often found in soil, water, and mishandled food) produce spores that can survive boiling at 1atm (sea level). The spores are heat-activated IIRC and would actually thrive in 100C water because all other competing bacteria would be eliminated. That's why if we want something really sterile in lab, we autoclave it (temps reach above 100C). I believe that's also the reason behind pressure-cooking? But my guess is the chances of you running into C. botulinum are slim, depending on locale.
ETA:
Nm, I guess it's actually the toxin produced by the bacteria that is dangerous, and the toxin itself seems to be eliminated by boiling. From CDC:
I wish they had them little aluminum flats of PP up here and they were available, of course.![]()
Good to know.
Have we had cases of botulism from drinking water? I know the spores are found in the soil. (So when eating dirt, boil for ten minutes.)
In the United States, an average of 145 cases are reported each year. Of these, approximately 15% are foodborne, 65% are infant botulism, and 20% are wound. Adult intestinal colonization and iatrogenic botulism also occur, but rarely. Outbreaks of foodborne botulism involving two or more persons occur most years and usually caused by eating contaminated home-canned foods. The number of cases of foodborne and infant botulism has changed little in recent years, but wound botulism has increased because of the use of black-tar heroin, especially in California.
Notes to self: Boil dirt before ingesting, home-canned foods are not as safe as once thought (B.S.) and lay off the California black-tar heroin.![]()
But water can't get any hotter than 100C right? at least in a standard pot. After that it just evaporates. Boiling water is the same temperature at a rolling boil as it is after 7 mins of boiling, correct?
I suspect that the advice about boiling for X minutes is just to ensure that the water is definitely boiling, as some people may not understand what a rolling boil looks like.
