1) Alloys in the steel chart are grouped by chemical composition, called reference groups. In addition, each group may contain alloy name which was listed by maker as an equivalent of a given alloy, in those cases note explicitly states that....I'm weary of anywhere that says sr101 *is* or *is not*
something specific without being able to site a source for the information, like zknives listing it as "52100 VAC-ARC":
http://zknives.com/knives/steels/steelchart.php
on what are you basing sr77 having higher toughness than infi?
'Malleability
A metal that can be hammered, rolled, or pressed into various shapes without cracking or breaking or other detrimental effects is said to be malleable. This property is necessary in sheet metal that is to be worked into curved shapes such as cowlings, fairings, and wing tips. Copper is one example of a malleable metal.'
'Toughness
A material that possesses toughness will withstand tearing or shearing and may be stretched or otherwise deformed without breaking. Toughness is a desirable property in aircraft metals.'
While both sr77 (modified s7) and infi have malleability and toughness at high hardness, it's always been my understanding that it takes more force to cause infi to deform than it does sr77. Likewise, it takes more force to make infi take a set during bend tests than it does sr77. Both will bend before breaking, and both will deform before shearing, but infi requires more force before doing so.
What experience or tests are you drawing upon to say otherwise?
I would agree that SR77 is stronger and tougher overall than INFI. I have beat my dogfather to death and the edge will dull but it has zero chips or dings. My basic 11 has several decent chips and dings.
Still, I figure it's better to clarify why things are in steel chart as they are.
