Quarantine Dream Users - Spyderco, Brous, Rike
Feedback: +14 / =0 / -0
71CDEA74-05B2-485E-BAC8-19E1DCB887A2.jpeg 03E5143F-921F-4800-B226-6390F73D6717.jpeg
1) Rike 1504b $240
Awesome knife, barely used. Great snappy action.
Overall Length:8.75"
Blade Length:3.75"
Blade Thickness:0.14"
Blade Material:CPM-S35VN
Blade Style: Drop Point
Blade Grind:Flat
Finish:Bead Blast
Edge Type: Plain
Handle Length:5.00"
The 1504B Flipper from Rike Knife offers smooth opening action for lightning fast blade deployment. This model is outfitted with a dark gray handle and a drop point blade with a light bead blast finish. It features solid titanium construction and an S35VN steel blade for extreme strength and durability. 3D machining on the handle provides a comfortable grip and a clean, sophisticated look. The 1504B includes a titanium pocket clip and lanyard hole for convenient EDC
2) Boker Plus Vox F3 II Frame Lock Knife Titanium (3" Satin) $100
Clip is scratched but functional. Slight wear on scales but no other issues. Great user!
Overall Length: 7.125"
Blade Length: 3.00"
Blade Thickness: 0.16"
Blade Material: CPM-S35VN
Blade Style: Clip Point
Finish: Satin
Edge Type: Plain
Handle Length: 4.00"
Handle Thickness: 0.47"
2968C3A6-4186-4AC5-A161-5893125E523D.jpeg 658B23F6-5BE3-475D-A987-B9F6BF429C26.jpeg
3) Brous Blades Silent Soldier Flipper Knife Carbon Fiber $190
#112 of 500
Second run of the model with better quality than current version. A small chip due to a drop is on the back of one CF scale.
This Silent Soldier Flipper features a stonewash D2 (2.5" Stonewash), double ground, double swedge. The spine has aggressive thumb jimping and a 7/8" finger hole in the blade for ultimate control. The pivot utilizes a ball bearing system and heat treated pivot and stop pin.
4) Spyderco Techno 1 with a brass scale. $150 - SOLD
Discontinued little big knife barely used. Small snail trail scratch on brass scale. Can only be seen at certain angles. Titanium anno bronze screws and standoffs to reduce weight.
Overall Length: 5.98" (152mm)
Blade Length: 2.55" (65mm)
Steel: CTS XHP
Closed Length: 3.43" (87mm)
Edge Length: 2.33" (59mm)
Weight: 4.3oz (123g)
Blade Thickness: .177" (4.5mm)
Handle: Titanium and Brass
Clip Position: Right handed
Tip Carry Position: Tip-Up
Grind: Full-Flat
Origin: Taiwanq
84C65AB2-B0D0-4A10-B6E8-B7A8B1546B8A.jpeg 199E8CB2-551A-492E-A7C2-12090C991560.jpeg
FSOT, Paypal only, Shipping only to CONUS
