I carried a CS Master Tanto into the woods thru the 80s. I took a bit of getting used to but it worked very well for me. The primary difference that I had difficulty in adjusting to was using the tip. With it sitting as high as it does above the center of grip makes it challenging to bore holes or any task that would require a straight thrust. Other than that it performed extremely well. I prefer drop points now but certainly wouldnt feel bad if I had to take a tanto.
What is an example of one you like or that has worked well for you? Just out of curiosity.
