- Mar 21, 2005
At least the flying spring didn't catch you in the eye. You wouldn't want to go around looking like this all the time --->
At least the flying spring didn't catch you in the eye. You wouldn't want to go around looking like this all the time --->![]()
What are the springs made of?
Lobster boats. Salt water. Corrosion?
I asked them that question some time back, after a thread discussion here raised the question (D2 or otherwise?). Via email, I was told they are 420HC. Should be more corrosion-resistant than the D2 blades themselves.
David
Springs, being under stress as they bend, are less corrosion resistant than other steel objects. An amount of corrosion which would go unnoticed in other objects can cause failure in a spring.
This is because, for steel under stress as a spring is, it only takes a bit of corrosion to create an initiation point for stress corrosion cracking. Stress corrosion cracking causes catastrophic failure, which is pretty much what Pete's knife spring experienced.
Grooooooan....!They might make a movie out of that knife,
Brokeback Mountain...man knife![]()
Did you prefer the traditional over a modern serrated folder for your line of work?
seriously though, it is fortunate that you were not on the receiving end of that flying piece of steel, could have been a lot worse and sounds like you had some good years with it and as others mentioned, nothing lost in trying to see if Queen will come to your aid and help you out, as it's not your fault a back spring broke!
G2
Kinda wondering the same thing myself. There are a few very well respected knives that are designed and made as industry specific tools that seem to working well in the fishing industry. Not appropriate to post them here, but there are some great options out there.
Robert
Dendritic Cobalt?
If so, how close does D2 get to that?
Pete, would a fixed blade work for you? I'm wondering if the Queen Drop Point Hunter in D2 would be a better traditional option. Toothy edge. Nothing to fail. Maybe grind the tip down more to more blunt tip? Matched with hanging Scandinavian style sheath?
