Quench discoloration question
I just quenched this blade. It is in sub zero bath right now. Is this bad? Do i need to be concerned? The blade is A2 (Aldo) 1/4" at the spine. Plate quenched between two 6061 2x4s. Austenitized @1750˚. That wasn't the whole HT routine but that's the temp from which I quenched. The SS envelope the blade was in had nice tight folds. I did not use a combustible inside the envelope.
As Devin said, it is no concern. Usually caused by a minute leak in the foil packet, or by oils and stuff in on the blade. You can get rainbows, blotches, colors, etc. None are a worry if everything else was done right.
