- Dec 7, 2000
Well, I recently switched to actual quench oil - Houghton G - for my O1 blades. I did a test to see just how good the stuff is, and I have a major problem.
Here's the setup. 3/16" O1 (cutoffs of my normal steel) soaked at 1455 for about 8 minutes. The program comes to 700 for 15 min then full ramp to 1455. I quenched in 140 deg G. I didn't time it but it might have taken 1.5 seconds to get from the oven into the quench.
When I went to break the test pieces before tempering ... they bent to about 45 degrees before breaking. They were fully cooled to room temp.
Can someone suggest where I've gone wrong here? I've used Brownell's Tough Quench with my one brick forge and gotten excellent hardening on small blades. I've quenched all my 'full sized' blades in common veggie oil at 140 deg previously - the only difference being the quench was much closer to the oven so time from oven to quench was likely shorter, though I've never timed this.
I don't know what's gone wrong here but this has to be resolved before I can make any more knives. I appreciate any ideas for process change and further testing. I can get some pics if needed but don't have any at this point. (I was so freaked out when my cutoffs didn't really break that I just shut everything down and went to do yard work.)
