- Aug 2, 2010
I was wondering what the drawbacks of quenching 52100 into parks 50 are. I'm going to HT 3 blades tonight and I don't have enough canola oil to disperse all the heat, on have a small bread pan full, so the oil will basically be too hot right after the first blade, not to mention I am going to normalize and thermocyle them with one quench each during the decending cycle heats prior to the actual quench so that won't help either. I usually only do one blade at a time but I made 3 similar blades and am doin the same stage on each of them at the same time. I do have 5 gallon of P50 though (maxim shipped it to me in a blue 5 gallon PLASTIC bucket), but I normally just use a 1 gallon paint can that I filled up with my P50 for single blades. (On a side note: Would it be dangerous just quenching 3 smaller sized blades with the oil still in the plastic bucket they sent it in?)
Is the drawback to not using a slower quench like canola oil for example for 52100 just that there is more chance for warping and cracks? Or does it cool it too fast that in some way inhibits it from fully hardening or reaching its potential? Just so you guys know what I'm dealing with, the 3 blades are ground only about a third of the acual bevel height and I left the edge about .040" thick. I'm sick of screwing up blades after HT which had perfect grinds ect. by taking too much off tryin to fix my grinds due to slight warpage or for w/e reason because I'm still teaching myself to freehand, and when I achieve a good bevel I don't like messin with it, cause 90% of the time I'll mess it up... So I decided this time to leave a good amount of meat and do most grinding post HT, but still establishing the bevel pre HT. The steel is Aldos 52100 and it's .110" thick and the widest part of the blade itself is 1" and I ground a bevel about .315" or about 1/3 of the way up the blade, and like I said left a thicker edge at about .040" for doing most the grinding post HT.
It has always confused me when I see guys at home doin larger batches of blades and HT them all at the same time using the same quench bucket, you would think, or at least I do, that each blades HRC for perfomance would turn out different do to the oil getting much hotter afte each blade, so the cooling rate would change and not be consistant. Is this a reasonable thing to be confused about?
Anyway if you guys can give me any advice on this subject I'd appreciate it a bunch
Thanks!
-Paul
www.youtube.com/Lsubslimed
-Paul
