Not intentionally burning the sawdust, but rather making charcoal of it in a way. Some of the dust will burn, taking the oxygen in the muffle with it. This is the oxygen that will cause scale and decarburization on the surface of the knife. If the oxygen is used up before the metal is hot enough for this to happen, you should in theory get no scale or decarb. Obviously this doesn't work perfectly, because oxygen is free to enter the open end of the muffle, so you will get some scale/decarb, but it seems to help. You will still have to grind/sand some scale and decarburized metal off of your blade post heat treat, however from my humble experiments it appears to reduce it a bit.
As for carbon migrating into your metal during the process, in theory it's possible, but you won't get any noticeable results, much less ones of value to the finished blade.
This is the only legitimate use of sawdust in the heat treating process that I'm aware of. Any other use of it, especially as some sort of quenching medium is likely a tall tale. Those who understand the heat treating process better than I - feel free to correct me.
Thanks alot![]()
does anyone have some insight into quenching with sawdust? ive done it where i am and noticed significantly less scaling. ive read some "more superstitious" claims and insights that it is better for the steel and carbon?....
It's a good idea. In our region some knifemakers do it. But wood sawdust with blade need to be closed into a stainless steel box with lid. Sawdust will burn oxygen from box and will keep blade away from it.
Dry sawdust, wood pieces or charcoal as Stacy wrote. Put blade in a box, fill in by dust or coal, tight close with lid. Add about 5-15 min on temperature depending on size and mass of the box. Box should be from austenitizing steel. It will last longer.Interesting. Im up in lapland in sweden and where i caught wind of the idea and tried it. I just dunkd it in a bucket of sawdust and there was noticable less scaling. But i could see where in a box would be great for the theory. Any tips on how long to dunk it in? Or time left? Is the saw dust wet?
Is this a serious post? If so im very curious and thanks for your input
Oh my god. Please never get near fire again.
