jdm61
itinerant metal pounder
- Aug 12, 2005
The Parks data that I read said that #50 is effective from 70-120F, so 130 is probably at the upper limit if this info is correct. I quench at room temp..........but room temp in Florida is a bit higher than some other places.....usually 80's-90's in the shop or worse
I have only had to heat my Parks once and that was back in January when the outside temp was in the high 50's to low 60's and it had been colder that morning. I only heated it to around 100-110 and it worked just fine. On W2, you can see when it hasn't fully hardened. I had that problem with Tough Quench on largish W2 blades even when it was heated to 150, which is it's sweet spot.
