- Dec 20, 2005
How many gallons would you use to quench a large bowie knife? 5160 steel, 5/16" thick, 10" blade.
I did an edge quench this evening using a cake pan (approx. a little over 1 gallon) filled with auto transmission fluid and it burst into flames!!
Threw some kaowool on it and smothered the flames, but as soon as I removed it ... it lit up again. To top it all off, I don't believe the blade was properly hardened! I can scratch it with a file. I'm going to give it another try.
Maybe I should dunk the whole thing and do a soft back draw instead of an edge quench.
Just wondering how much quenchant is recommended for how many pounds of steel? Is there a general formula? If there is, I'd like to weld up a custom steel vertical quench tank with a cage (so I can move the blade up and down while it's cooling) and a lid (in case of fires). Any info or recommendations would be really appreciated! :thumbup:
