Charlie, The problem is there is a lot more than HARD happening when you HT steel.
When you harden steel in the quench the structure of the iron and carbon rearranges from the austenite that forms above the curie point (non-magnetic) to martensite -assuming the quench was fast enough to avoid pearlite forming. You will get the same hardness with every quench, regardless of how hot the steel was ( 1700F doesn't make it harder than 1500F). What does happen at the higher temperatures is grain growth ( and some other undesirable things) which makes the steel more brittle.
The reason you need to know the make-up of the steel (not just a guess) is the temperature,soak time, and type of quenchant are all determined by the composition of the steel.
Let's take your blade .It came from a saw mill blade. That could be anything from 1030, to L-6, to 9260, to 1095 ( actually 1095 is unlikely), or something entirely different ( often called "Chrome-moly steel"). If it was L-6 it would need a different quenchant and HT specs than if it was 1095. You can experiment with some samples and come up with a HT that will harden it, but without testing equipment and microscopes, it will only still be a guess as to how well the steel is hardened.
The temper done after the quench (it should be tempered as soon as the steel returns to room temperature) will be a function of the steel type,too. The temper is where the brittleness is modified into toughness, reaching a compromise that is desired for the blades function and use.
So, you see why it would be better to start with a known piece of steel and design the HT parameters around that knowledge.If you have a large amount of what appears to be good steel (60" saw blade) send a 1X4" piece to be tested, then you will know the composition, and your "Found Steel" may become "found money".
Stacy
