Also, when you place the blade in the oil (on the rack RHankins mentioned) ,quickly rock the blade from tip to flat edge and back to make sure the raised tip area gets hardened properly. You need to have more of the blade under the oil than the desired hardness area, due to the hot and uncooled spine pushing the boundary somewhat below the surface of the oil.
I am not a fan of edge quenching. Using clay and fully quenching the blade gets better results with much more control over what is happening.
Stacy
