- Sep 21, 2014
What grit stone do you start with? My coarse wet stone is 800g.it only takes a few minutes to raise a burr on a course whet stone
First is 1000, second is 6000. Again these are japanese waterstones, not whet stones. Not sure if the “grit” translates directly. If you have not used waterstones (???) they behave very differently from Arkansas stones. I love themWhat grit stone do you start with? My coarse wet stone is 800g.
Ok, if that's what we are using in this thread.“the primary edge on a blade is the sharp edge that can cut you. The primary edge initiates a cut. The secondary edge is the V-shape of the blade starting right behind the primary edge which dictates how easy or difficult it is to pass the blade through things. Cutting a string or thin paper is all about the primary edge, whereas trying to cut through acorn squash or thick shoe leather involves more of the secondary edge.”
i think if you do at least 600 grit then strop it you won't see grind lines on the primary, it'll just look shiny. i suppose it depends how smooth you want the edge along it's length?My original question was based on my thought that, on hunters/choppers/EDCs, establishing the primary bevel (referencing Alex's posted diagram above) on the grinder with a 400g belt would allow one to see grinding lines from the 400g belt on this primary bevel compared to the flat of the blade where I use 2000-5000g when hand sanding.
The smoother, the sharper.i suppose it depends how smooth you want the edge along it's length?
A few light passes on a 240 but I quickly move to 1000 where most of work is done. I do a quick strop to make sure it'll shave off 1000 but then jump to 4000 before the final strop. On my own knifes I'll go up to 8000 but I found with customers knifes 4000 is better as they aren't stopping the blades at all so a 4000 finish lasts longer for skinned vegetables. 8000 can loose that clean edge and slide on vegetables but still cut a finger like butter.What grit stone do you start with? My coarse wet stone is 800g.
