Question about stabalized wood
Hello everyone. I just have 2 questions about stabalied wood. 1.) If I buy a block of dyed/stabalized wood, does the dye go all the way through the wood? 2.) Do I need to apply any other type of finish to the wood after it is fiinish sanded?
If it is done by one of the real professionals in the business then the dye and polymer does go all the way through. The only finish I apply to my stabilized wood is paste wax. I occasionally put a little wood stain on some of the lighter pieces (not dyed) to help bring out the figure.
Stabilized wood burnishes well. Do this after final sanding using a stiff leather edge. You will be amazed.
A little wax is all that is needed to finish.
Fred
You have to give old Fred a little time. He has to go outside and look up into the sky to see if he is still where he thinks he is.:D
Robert
How did you know that? I used to write it on the back of my hand until the scar tissue got so thick it wouldn't take the ink.
Fred
Thanks alot for the help guys. Where are you Fred? Just curious.....I'm in Strasburg.
Hey Smitty,
I'm about 20 minutes above the Ohio river, in Washington co. A little place called Bartlett. Its on SR 550 halfway between Athens and Marietta.
Fred
Wow, I didn't realize that there were any accomplished knife makers so close to me.
You are welcome to stop by my forge if you get this way.
I am always interested in meeting fellow enthusiast.
PM me if you are interested.
Fred
Fred
Ok, so what is burnishing exactly? And what is a "stiff leather edge". I'd like to give this a try, but not understanding the process. Thanks.
I am pleased that you asked.
Burnishing is the process of " rubbing the surface of the wood " briskly in order to bring out the grain.
The wood itself, can be looked at as a stack of closely nit fibers.
When you are working with burl, it is a stack of fibers that have been tied together in knots, so to speak.
When you sand these fibers, they are being "cut" by the abrasives. Or in other words you are shearing the fibers of the wood.
When you burnish, this process, " molds" "blends" and "polishes the wood fibers, at the surface.
The end result, is a very smooth highlighted surface, that when waxed, looks almost like a piece of marble.
You can burnish using the side of a 1/4 inch brass rod, a stiff piece of 9 or 10 oz leather; blue jeans material makes for a great burnishing tool.
Try it by sanding a piece of stabilized wood to a 1200 grit finish, this is where many people stop. From here, hold the block firmly in one hand, while in the other you use the edge of the rod or leather to "stroke" the wood along the grain, using pressure and a brisk motion. Watch the surface of the wood and you will see the grain highlights appear with more intensity. Finish with the blue jeans material, again using a rolled edge to "burnish" the wood.
I would be interested in how you like this technique.
Good luck, Fred
