I have attempted 3 stockmans, and haven't been happy with any of them. I started looking at all different kinds of stockmans. Buck makes a stockman with 3 single springs. It's a very wide knife, and is essentially three knives peened together. Case makes a stockman with one single spring and one double spring with a liner between them that is gound down very low on the inside of the knife, and the middle blade is actually bent slightly at the tang so it fills in the space over that middle ground down liner.
The first i attempted had 3/32" blades with a single and a double spring with a liner between, and the two overlapping blades were flat ground to 3/64" before doing the bevels. This creates a very steep plunge and I don't like the look of it. I tried tapering that plunge and it still doesn't look good. I also tried using 1/16" steel for the overlapping blades and 3/32" steel for the double spring, and soldered some 1/32" spacers to the liners. It looked weird and I didn't like it, and it is hard to actually do. I also tried 1/16" steel ground to 1/32" and those blades were paper thin and very flexible, I didn't like that, 3/64" seems about the thinnest I'd ever want to go.
I like the Case design best, so i want to try that now. The problem is, how the heck do you get that sharp bend at the tang? I just see myself bending a gentle curve throughout the whole blade and it not working. There's probably a way to use my vise like a press, I'd just need to make a form or something. Anyone ever done this? Intentionally bend a blade into an angle?
