Question about the Zero Tolerance 0121 and sheath
VR4
Does anyone know if the Zero Tolerance 0121 can be mounted in the sheath for a left hand draw? I've searched all over and have never found this issue addressed... from some of the pictures though, I don't have high hopes.
Anyone have a definitive answer about this?
Bump... I also emailed ZT a few days ago but haven't heard back from them
I don't have one--you'll have to wait and see if someone here who has one can check. I only know that it doesn't matter for the 0150 sheath.
It looks like since it uses screws for the snap-clip mounting system, that you might be able to make it kinda work for a lefty? But then you would have to not use the secondary retention strap. :(
Just got mine and it won't work without removing the snap, and rigging the mounting screws with washers or such to make up the difference in the thickness of the sheath/blade. The knife sits more to the right in the kydex, the one side is flat the other is not. Does that make sense? I can email you pics...
