question about working with stabilized coral
I usually super glue my handle slabs to my liners to keep everything in place while I drill and set my pins. would the heat given off from the supper glue curing cause the epoxy in stabilized brain coral to warp? I am planning on to use orange brain corral over black g-10
thank you for your advice
Dan
I use super glue a lot at work.
Mostly on leather and rubber. I never noticed enough heat to speak off.
My guess is that your hands give off more (body)heat then the glue will.
I'm pretty sure cyanoacrylate cures anaerobically, like epoxy, so it would make sense for it to give off heat. It would probably help to know the kind of epoxy used to stabilize the coral, but I doubt it would cause any damage.
Several things.
1) Is the coral stabilized, impregnated, or reconstituted? That makes a big difference in how you work it. In all cases, use fresh belts, slow speed, and don't let it get hot to the touch. Much of the stuff sold is "Reconstituted"....which is just ground up material that is mixed with dyes and epoxy. It looks OK, but is mainly decorative.
2) Most resins cure exothermically. The polymerization gives off heat. Epoxy and CA both give off heat when curing. The film thickness is what limits that to being virtually undetectable in most cases. In mixing epoxy in larger batches, you should spread it out on a large surface or wide bowl/tub after mixing to slow down the heat build up. A pot of epoxy that is mixed in a plastic drinking cup can get too hot to hold. Similarly, if CA is applied thickly, or an accelerator is used, it can get pretty hot. Other reactions with the materials being bonded can cause it to get very hot, too.
3) There is more worry about the heat from grinding and shaping than there is from the CA or epoxy.
4) CA is a great product, but it is used for many things it isn't the best at. Attaching scales and handles should be done with a slow cure epoxy. That also allows dye powders to be added to the epoxy and closely match the handle material color.
Blade smith
thank you for the input,
1) the Coral is stabilized
2) I use supper glue to hold the liner to the scale when I build the slabs, then use g-flex to glue the the handle to the tang while I pin it.
In would use the same resin to attach the liner as I would the whole assembly.
Speaking of Q-Flex, have you used it on neoprene. I am considering it for my neoprene handles.
I tested G-Flex, regular superglue, rubberized superglue and barge cement on a stall mat/G10 laminate and the G-flex won hands down. I just used it on some neoprene and it seems fine but have not tested it for that.
I have not used used neoprene yet, I have a sheet that I am toying with I will let you know how it goes tho.
