The grizzly will occaisionally have belts come off when slack belt grinding, and trying to do sharp plunges on the edge of the platen doesn't work well
-Page
Could you post a picture of your third wheel set up? It sounds interesting but I just can't picture it in my head.The way that I got around the hollow grinding problem on the Grizzly was to remove the platen and to mount a third wheel in it's place. I ordered a Bader wheel (I hollow grind on a 14" wheel) w/axle and bearing and made a mounting bracket from a piece of 2" center bored rod welded to a piece of
1/4" x 2" bar with mounting holes to match those on the platen. Works wonderfully and only takes a couple of minutes to switch it out.
Gary
If you are having problems with tracking or throwing belts it's probably a lack of belt tension. The tension spring on the Grizzly isn't sufficient to apply enough tension to the belt. Tighten the belt enough to compress the spring completely and you shouldn't have any more problems.
Gary
