- Aug 8, 2013
How do yall find is the best way to sharpen these blades? Ive got a mini on the way and ive had issues with recurve blades in the past.
Thanks
Ian
Thanks
Ian
I have always used a Spyderco Sharpmaker on my Emersons, you just have to tilt the blade so that the rods are making contact correctly with the edge.
I would suggest using a Sharpie to color the edge, that way you will be able to tell if you have the knife tilted enough or not when making your strokes down the rods.
Use the corner of the rods for the recurve, that way you will get all of the edge, just be sure and take it slow and don't let the tip slide off the rods, you can round the tip off if you do.
A few light passes on the backside will knock the burr off and your good to go.
What slot do you use Boru? It has been forever it seems since I've used mine. Use the ceramics or just use the diamond rod.
Doesn't really matter whether you use the 30 or 40 degree slots, you will be tilting the knife anyway to match the angle of the edge. I just use the ceramics, haven't had the need to use the diamonds.
