Lately I have been having a problem achieving centered blades between liners when in the closed position. I have checked drill press and in a 4" radius of revolving pc of wire I have less than .001 variance from side to side to top of table. I drill and then ream 2 thous over pin size(3/32). There is no binding on pin. I recently decided to try 3/16 bushing and have lapped to .0015 over blade thickness abnd followed the Bose bushign tutorial. No help although the action has improved...smoother, etc. Everything, in my opinion, is good on knife other than centering problem. When peining I shim equally on both sides and then pull shims....not centered. Ugh..... What else could it be. I have sharp bit, reamers, etc. Just very aggravating to spend hrs and then have these problems. The knives are not always canted to one side or the other.... Ugh. At times I even leave blade a little thick at point and then grind a bit more on one side to even up..but this should not have to happen..should it? Any help here is really appreciated. Thanks in advance.
John Lloyd
John Lloyd
