Question for the forgers out there.
Hello everybody. I'm new here and new to knife making. I have the big stainless bolts laying around and was wondering if you guys thought it would be worth my time to forge one into a knife. And what kind of quench would you recommend? Thanks.
Try forging them into other decorative or non edged or impact tools. They may crack but if they are free you will still learn something. Get knife making steel designed to be forged to make blades, it cheap and made for the task at hand.
you could buy some mild steel from McMaster Carr to practice forging to get started and learn the hammer techniques
it would not be worth my time. I don't know what you value your time at... if it is not much then go for it. beat the heck out of it and quench in something wet. report results back to us.
Most likely a 300 or 400 series steel and not hardenable. I will tell you from personal experience forging any stainless is a bit tougher than forging carbon steel. I've never forged stainless knife steels, but I have forged low carbon stainless and it's a bear to forge and you have a smaller forging window. Get some 1084, or 5160, or even car springs and with a little work and a half way decent heat treat will make a decent knife. There is no point to forging stainless steel. I remember reading where David Boye was forging 440C to shape in the 60's or 70's as there was no flat stock available at the time. He sent some off for micrographs and discovered there was no grain refinement from forging so just started turning round stock into flat stock. That was a long time ago, you want a stainless knife, the easiest way is to grind it out of flat stock.
A lot of stainless bolts are also 18-8
I have a big 1" diamater inconel bolt from a 737 plane and I'm not forging that lol
