glocker199
- Mar 14, 2005
For those who carry a slip joint as a primary blade: Any specific reason for doing so, other than aesthetics or nostalgia? Just curious.
I find the thin blade stock and thin grind to out cut any of the other style knives I own, even when the other knives are ''sharper''.
I find the thin blade stock and thin grind to out cut any of the other style knives I own, even when the other knives are ''sharper''. This is particularly true with a properly made custom knife.
In addition to the reasons already given, I also like how many slip-joint folders offer secondary tool blades. Whether it's a pen-blade, an awl, a cap-lifter or a combination of tools like a SAK, it gives you more options...
But hey, why not carry both?
-Brett
The real difference is made in the thickness behind the edge - a properly ground slip joint should be almost as thin as a chefs knife behind the edge. For example, my sebenza is made from 1/8'' thick steel or .125 inches , my slip joint is ground from 3/32'' stock .093 inches. Behind the edge my slip joint is ~ .005 inches, my sebenza is closer to .020+ behind the edge. So even though my sebenza will currently shave hair and my slip joint wont, I find the slip joint to move through material better.
that being said, the thickness on a SAK tinker is .07'' which is very thin and I can not think of one modern folder that uses such thin stock. My delica comes close at .09'' but again, the thickness behind the edge makes the SAK a better slicer.
1) I use my knives to cut things. Thinner cuts better than thicker.
2) I don't use my knives to stab things, or perform spine whack tests.
3) I don't need a giant penetrator/stabinator to whip out of my pocket.
4) I have fixed blades for when I need a lock or a larger blade.
5) They look great.
